Do not use a camera which is not in the list even if you can handle its RAW data, because we do not provide any support for it. You cannot get the normal development result with an unsupported camera. It also may cause hang-up of this software. We are trying to add as many cameras as possible to the supported camera list. The current list is available in our SILKYPIX® web site (http://www.isl.co.jp/SILKYPIX/english/products/). [Supported camera list] (As of SEP/11/2006) • Canon
EOS-1D Mark II EOS-1D Mark II N EOS-1Ds EOS-1Ds Mark II EOS 5D EOS 10D EOS 20D EOS 20Da *4 EOS 30D EOS D30 *2 EOS D60 EOS Kiss Digital/EOS Digital Rebel/EOS 300D EOS Kiss Digital N/EOS Digital Rebel XT/EOS 350D EOS Kiss Digital X/EOS Digital Rebel XTi/EOS 400D PowerShot S30 PowerShot S45 *1 PowerShot S60 *1 PowerShot S70 *1 PowerShot G2 *1 PowerShot G5 *1 PowerShot G6 *1 PowerShot Pro1 *1
D1X D1H D2H D2Hs D2X D2Xs D50 D70 D70s D80 D100 D200 CoolPix 5400 CoolPix 8400 CoolPix 8700 CoolPix 8800
E10 E20 E-300 E-330 E-500 C5050Z C5060WZ C70Z C7070WZ C8080WZ SP350
α Sweet DIGITAL/Dynax 5D/Maxxum 5D DiMAGE A1 DiMAGE A2 DiMAGE 7 DiMAGE 7i DiMAGE 7Hi DiMAGE A200
*ist DS *ist DL *ist DS2 *ist DL2 K100D
DMC-LX1 DMC-LX2 DMC-FZ30 *6 DMC-FZ50 *6 DMC-L1
R-D1s *1
Pro SLR/c *3 Pro 14/n *3 Pro 14/nx *3 ProBack *1 P850 *1 P880 *1
A100
GX-1L
Basically, although this software doesn't reflect the setting values of the camera recorded in RAW data, it reflects the WB setting as much as possible. Since we have little information about camera settings of some models, they are not supported.
*2 ... Although the WB value setting of the camera is acquired, AWB is treated as sunlight. *3 ... The WB setting value of the camera is not acquired.
*5 ... Supported DNG is limited. *6 ... In some mode, the number of recorded pixels is different from the development result created by the camera internal. *7 ... Attached with R8 or R9 only. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
