16.1 Registration Processing
When you complete registration procedures, you are registered and our support service becomes available. * In principle, we do not offer supports for a guest who has not registered yet and who is using a Free Mode.
Also, we cannot provide any support service for a device without our guarantee of proper operation.
Visit our support form site in our SILKYPIX® web site (http://www.isl.co.jp/SILKYPIX/english/support/). *Your license serial number is required to use the support form site, check your number in advance. Please note that you have to pay the Internet connection fee and other connection fees.
If you cannot use the above support form the site because of a problem on Internet connection problems or other troubles, fill in the following guideline and send it to the SILKYPIX® support center (silkypix_support_english@isl.co.jp) by e-mail. [Inquiry Guideline] • SILKYPIX® serial number • Name • Mail address (do not type a free-mail address or mobile phone address here since some information may not be sent by e-mail) • SILKYPIX® version • OS • PC (manufacturer and model name) • CPU • CPU speed (GHz or MHz) • The number of CPU • The amount of memory installed (GB or MB) • Free space in HDD (GB or MB) • Digital camera (manufacturer and model name) • Questions
To check your serial number, follow the procedures below. (1) The button or the menu [Help (H)] - [Version information (A)] displays the "Version information" dialog. (2) Check your serial number in the "Version information" dialog.
The certification procedures require plain environment to connect Internet. Check the following points when performing certification procedures. - There is no need to connect all the time. Internet connection is required only when you perform certification procedures. - Once you complete certification procedures and start operation of the Product Mode of SILKYPIX®, you don't need certification procedures again, unless you uninstall or re-install the software. Internet connection is also not required to use the software. - Since a virus checker, a security software, a personal fire wall, etc. monitor the Internet transmission and block transmission of the non-authorized applications, they cause an error when you perform the certification process of the SILKYPIX® software. Therefore, before performing certification procedures, make these security softwares invalid temporary. 16.6.1 Error Dialog List at Certification Proxy certificationProxy server (alternate server) certification is required to connect to the registration server. Enter the user ID and password of the proxy server. • Cause
Error100xCertification is not completed. This certification exceeds a regulated frequency. • Cause
If you need re-installation or re-registration after replacing or upgrading your PC, contact our support center. * If you have no idea that you have done certification procedures, but this error appears, there is a possibility that the key is stolen, so, contact us immediately. Error 101xCertification is not completed. The product key you entered is invalid. • Cause
It also occurs when degradation of transferred information (for example, garbled characters) arose for some reason and the key code sent to the server was wrong.
Error 102xCertification is not completed. The product key you entered is suspended. • Cause
Even if the key code is correct, we may decide to stop the key (when we find that it is stolen or violates the license), and the server rejects certification at that time.
Contact our support center. Error 103xCertification is not completed. The transmission was disconnected. • Cause
Usually, certification job at one time increases the certification record by 1, but this code shows that certification process was repeated for some reason and the certification record was increased by more than 2.
Error 200xCertification is not completed. The transmission was disconnected. • Cause
Check your connection line and try the process again. Error 201xCertification is not completed. The transmission was disconnected. • Cause
It is displayed when the line was disconnected, or response from the server was cut off. Also there is another possibility that excessive traffic caused the packet disappearance. It is also displayed when the server did not respond for a given length of time, or an error other than abnormal response occurred.
Check your connection line and try the process again. Some security software products may cut off communication, so if you are using those software products, change the setting of them to enable connection with SILKYPIX®, and try certification process again. Stop using a file exchange software or browser temporarily. If the cause of the error is a packet disappearance caused by excessive traffic, you may restore communication by stopping other transmission software. Error 202xCertification is not completed. The transmission was disconnected. • Cause
This error is generated when the server did not receive process commands, when the server is suspended, or when the line is not connected. It also appears when the security software cut off communication.
Check your connection line and try the process again. Some security software products may cut off communication, so if you are using those software products, change the setting of them to enable connection with SILKYPIX®, and try certification process again. Error 203xCertification is not completed. The transmission was disconnected. • Cause
Check your connection line and try the process again. Some security software products may cut off communication, so if you are using those software products, change the setting of them to enable connection with SILKYPIX®, and try certification process again. Error 250xCertification is not completed. The transmission was disconnected. • Cause
The OS returns an error when IP address was wrong or could not be acquired.
Check your connection line and try the process again. Some security software products may cut off communication, so if you are using those software products, change the setting of them to enable connection with SILKYPIX®, and try certification process again. Error 251xCertification is not completed. The transmission was disconnected. • Cause
Check your connection line and try the process again. Some security software products may cut off communication, so if you are using those software products, change the setting of them to enable connection with SILKYPIX®, and try certification process again. Error 400xCertification is not completed. Contact us. • Cause
Contact our support center. Error 401xSince maintenance of the server is going on, certification process could not be executed. Try the process again after a brief interval. • Cause
Check the maintenance information in our web site and try the process again after a brief interval. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
