9.1 Setting for Developed Image ![]() 9.1.1 Setting of File Type In this software, you can save a TIFF file as non-compressed format and a JPEG file as compressed format. 9.1.2 Option for JPEG/TIFFWe recommend you to use TIFF when you do not want to deteriorate a developed result in this software or when you process a file with photo retouching software. When you process a developed image file with photo retouching software, it is advantageous to save it as the 16-bit data that are useful for high gradation. When you want to reduce a saved file size, JPEG is suitable for saving. However, since a picture will deteriorate, you should set an optimal compression ratio as usage. In addition, you can record Exif information into an output file. Refer to '10.4.2 Exif Information' for more details. ![]() You can select a TIFF file type from following three types. RGB Exif-TIFF (8-bit) This is non-compressed format TIFF in conformity with EXIF standards, 1 channel is 8-bit and has R,G,B 3 channels including EXIF information. RGB TIFF 8-bitThis is non-compressed format TIFF, 1 channel is 8-bit and has R,G,B 3 channels without EXIF information. RGB TIFF 16-bitThis is non-compressed format TIFF, 1 channel is 16-bit and has R,G,B 3 channels. You can attach the EXIF information into this TIFF file if you check the "Recording Exif-IFD" checkbox. * "16-bit TIFF" is not prescribed in the Exif Standards. ![]() You can select a JPEG file type from the following three types and specify the quality coefficient. Regarding the quality coefficient, a smaller value makes the smaller file that records lower quality image, and a larger value makes the larger file that records higher quality image. Exif-JPEG (YCC422) This is a JPEG file including the EXIF information which has 2 pixels of color information per 4 pixels of lightness information. Exif-JPEG (YCC420)This is the most popular format. Because only a half of the chroma information is recorded, the compression ratio becomes higher, however, color separation degrades at a fine area. This is a JPEG file including the EXIF information which has 1 pixel of color information per 4 pixels of lightness information. JPEG (YCC444)The chroma information is recorded less than YCC422 described above. Therefore the size of the file becomes smaller but the image quality degrades more. Because all chroma information is recorded, the size of the file becomes larger and the degradation of the image quality is less. You can attach the EXIF information into this JPEG file if you check the "Recording Exif-IFD" checkbox. * JPEG YCC444 format is not prescribed in the Exif Standards. ![]() This setting does not have any influences on the results of the picture. Only the incidental information recorded in the image is influenced. [Resolution] The recorded "resolution" in JPEG and TIFF is defined here. The default setting is 300dpi. Even if you increase the dpi setting, the resolution of an outputted picture does not change at all. The value set here is recorded in EXIF information, and used as a standard to convert it into an actual size when the image is displayed or is printed. [Record ICC Profile] If a software is not compatible with the dpi information, this setting does not have any meaning. If you do not understand this setting well, please use the default setting. ![]() If you are using the photo retouching software which is compatible with color management, namely, a recorded profile, it can transfer the colorspace information correctly. This setting allows you not to record the information into a JPEG/TIFF file, which is the information about taking a photograph and the development parameter of SILKYPIX®. [Not record thumbnail]This setting is not checked in the default. The photography information is recorded in the information tag of EXIF, which includes all data of the photography and the time and date. The development parameter of SILKYPIX® is stored in "Makernote" tag of the EXIF information. Please use this setting if you do not want to disclose the information about taking the photograph and developing with SILKYPIX®. This setting allows you not to record the thumbnail into a JPEG/TIFF file, This setting is not checked in the default. [Not record orientation]This setting allows you not to record the orientation information to the "Orientation" tag of EXIF. This setting is not checked in the default. [Set 'CustomRendered' as 'Custom']This setting is specified to record "CustomRendered" tag of EXIF as "Custom" or "Normal". This setting is checked in the default. When this setting is checked, it is recorded as 'Custom process' to the 'CustomRendered' tag. It indicates the special processing was performed, and a next process is expected to disable or minimize any further processing. When this setting is not checked, it is recorded as 'Normal process' to the 'CustomRendered' tag. It doesn't expect like the above to a next process. If this setting is checked, for example, the image processings such as the automatic correction will not be performed when requesting the print of the photograph by the DPE service. If you expect some image processing to a next process, please remove the check of this setting. Since SILKYPIX® presupposes the output of the complete image which incorporated the intention of the user, it expects a next process to disable or minimize any further processing in the default setting. These are the setting how to develop to a JPEG/TIFF file. These setting affect the developed image itself. 9.1.4 Default Folder to Save[Rotation: Rotating images to save] ![]() When this setting is checked, a developed image will be rotated as same orientation as a preview image. When this setting is not checked, a developed image will not be rotated. In this case, the orientation information is separately recorded in the EXIF information if the "Not record orientation" described above is not checked. When you use the software which is compatible with the orientation information (like this software), the picture will be displayed which is rotated with the orientation information. In this case, you cannot distinguish the differences whether this setting is checked or not. If you disable this setting, all developed images will be same orientation. It is useful when you use the same action of the photo-retouching software at a later stage. ![]() It is useful, for example, if you would like to print out with "Adobe RGB" colorspace and also save JPEG files for web site with "sRGB" colorspace, you need not change each development parameter. ![]() You can specify the default folder to save the developed JPEG/TIFF files. This is a default setting for the "Save as" dialog and you can modify to any folder for saving every time. This setting does not affect for the "Batch development" function, because it has another setting for itself. ![]() You can specify the default filename to save the developed JPEG/TIFF files. This setting is "%N" in the default, which means the same as the basename of each RAW data file. This is a default setting for the "Save as" dialog and you can modify to any filename for saving every time. This setting is also used for the "Batch development" function. You can set the control character here. Click [Base], [Focal Length], [F Number], [Shutter speed], [ISO speed], [Date/Day], or [Time] button, the related control character is input automatically. If the [Initialize] button is clicked, it will initialize to "%N". You can also use your keyboard to input any character directly. [Control characters for specifying default filename]
9.2 Display Setting ![]() The menu command [Option(O)]-[Display setting(D)] displays the "Display setting" dialog, which you can specify about color management, control location and other display settings. 9.2.1 Color Management ![]() This setting specifies the color management for your display/monitor. If you check this setting, the color management is enabled and the selected monitor profile is applied for the displayed image. We recommend you to enable the color management and select the suitable monitor profile for your display/monitor. The monitor profile is sometimes distributed by the manufacturer, please check the web site of the monitor manufacturer. The best way is to select your own monitor profile for your environment created by any color matching utilities. You can reproduce the correct color on your display/monitor with color management. If you use "Adobe RGB" colorspace, we strongly recommend you to enable the color management. 9.2.1.1 Monitor Profile ![]() (1) Use the default monitor profile set in the OS. About how to specify a monitor profile to the OS, refer to your OS manual. (2) Select a monitor profile (ICC/ICM file) from files. You should specify a monitor profile that is defined in XYZ-RGB format. ![]() You can specify the location of the "parameter control" that is main GUI control. You can set it left side (default) or right side in the main window, or change it to a floating windows.
![]() You can specify the number of horizontal scenes for thumbnail view, and the order of sort. Please refer to '3.14 Sort Thumbnail' for the detail about thumbnail sorting. ![]() If this setting is checked, the "Grid setting" dialog will be displayed while the grid is displayed. This setting is valid in the default. [Enable auto grid display while editing rotation/digital shift] It is possible to change the grid position by using the [CTRL] key + drag even if the "Grid setting" dialog is not displayed. If this setting is checked, the grid is automatically displayed in a few seconds while editing rotation/digital shift parameters. This setting is valid in the default. [Make operation comfortable by reducing the load] If you check this setting, "Formal Development Preview" is not displayed when displaying preview image smaller than 100%. And the parameter adjustment becomes able to be lightly done. But you should make a display magnification equal to or more than 100% when you would like to confirm the effect of "Sharpness" or "Noise reduction". This setting is effective for the PC that has few built-in memories (less than roughly 1GB) or a notebook PC. 9.3 Function Setting ![]() 9.3.1 Setting 9.3.1.1 Saving Rotation for JPEG/TIFF/DNG 9.3.2 Operation![]() • Save to the parameter file (Never modify the original file) The rotation information will be recorded in a parameter file, and the original file is not modified. • Modify the tag (Modify the original file)The rotation information will be recorded into the original file which will be modified. * Software must be compatible with rotation information which is recorded in the orientation tag of EXIF.Since the rotation information is overwritten in the original file, other software (*) besides SILKYPIX® can recognize rotation information. However, if no rotation information is recorded in the original file, rotation information cannot be overwritten, and it is recorded in the parameter file (.spd). ![]() The "brightness level" means a value on a linear basis (photo energy) at the point you click. In other words, it is a value before adjusting contrast, gamma and tone curve. Therefore, even if you set 50%, a pixel value at the point does not become 127. The pixel value becomes the brightness level that is displayed on a display. which is processed with contrast, gamma and tone curve. Please consider that this value is treated as the image sensor level on the RAW data. For example, when setting this value as 18% and using the exposure bias tool by clicking on the "18% gray card" portion, you can obtain the exposure bias value that the pixel value on the RAW data is treated as 18% gray level. You can obtain almost the same result as a case of determining an exposure bias by using an exposure meter. If setting this value 85% even when not using a gray card, you can adjust an exposure bias to a certain level easily by clicking the brightest portion such as a white paper with the \nohit"Exposure bias tool", because the reflectance of a white paper is approximately between 80 to 90%.} You can reproduce the brightness which is the same as the other scene at the same point by applying this technique, when taking multiple photographs of the same scene. ![]() ![]() ![]() If this setting is not checked, the modified development parameters and rotation information are lost when this software is finished or when a new file or folder is selected. If this setting is checked, data files (spd, spi) for SILKYPIX® are created automatically into the "SILKYPIX_DS" sub folder on the folder in which a RAW data file exists. When this setting is not checked or a storage media is write-protected, these folders and files are not created. ![]() When this setting is not checked, RAW/JPEG/TIFF files are displayed together. When this setting is checked, only a RAW data file is displayed. * When this setting is checked, you cannot operate the RAW data file of EOS-1D or EOS-1Ds, because the extension of their RAW data file is "TIF" that is same as a TIFF image file. 9.3.2.1 Assign Double Click Operation as Selecting Folder 9.3.3 Performance![]() When this setting is checked, you can decide the folder to open by double-clicking. When this setting is not checked, you can open or close the folder on the tree view by double-clicking. In another word, it is an operation for the tree view in this case. ![]() When this setting is checked, an operation mode does not change even if you specify a point or area with these tools once. And you can continue to operate with the same tool. When this setting is not checked, these tools function as a one shot tool. And operation mode will be changed to the previous mode after using a tool. In addition, when you use these tools with [SHIFT] key, the "one shot" and the "continuous operation" function oppositely to the setting. ![]() If this setting is not checked, you need to confirm when you delete a file. If this setting is checked, you can delete a file without confirmation. 9.3.3.1 Enable Cache Preview ![]() This is effective when you check details on a picture by switching two pictures on the preview screen. When you check this setting, memory space for cache increases. When you use a PC with little memory, please uncheck this function. • Only previous and next scene cache When this setting is selected, SILKYPIX® caches only the previous and the next scenes and you can move to the previous scene or to the next scene quickly. • Maximize the use of CacheYou can check details on a picture by switching two pictures on the preview screen comfortably. You can cache intermediate development result and developed result of the five scenes at a maximum and the four sets of cloakroom. You can switch scenes quickly in the preview mode by the previous and next scene feed function. If you compare scenes by feeding to the previous and next scene with multiple pixels, you can check focus on the scenes that were taken in the continuous shooting mode and camera shake easily. Also, when executing putting development parameter on cloakroom, the development result is also cached simultaneously. When you compare scenes by switching the parameters on the cloakroom, you can switch to the preview quickly and run-in development parameters easily.
![]() If you can specify a folder in a physically different drive from the drive which OS is installed, performance may improve. When you specify a drive, you should specify the drive which has sufficient free storage space and also runs at as high speed as possible. ![]() 9.4 Setting for Troubleshooting You can set following settings according to the instruction from our support when troubles occur in your system environment. Note that when you change settings by your own judgment, there is a possibility that a program does not run normally, or the performance drops significantly. 9.4.1 Troubleshooting for Windows ![]() 9.4.1.1 Disable to Access Files with Memory-mapped Method 9.4.2 Setting for Troubleshooting Macintosh![]() In order to achieve smooth operation even during complicated processing, SILKYPIX® has adopted multithread processing and multiprocessing in a positive way and achieved high performance by operating microprocessors with high efficiency. 9.4.1.3 To Develop SlowlyAs the result, there is a possibility that SILKYPIX® decreases performance of the other software which are running simultaneously because the microprocessors are handling heavy loads during development processing. In addition, because the microprocessors are handling heavy loads, hardware operational failure has been reported. For example, a high temperature warning because of increased temperature of the processors, unstable operation, rebooting a PC and so forth. In order to avoid these trouble, this setting controls microprocessor activity ratio and limits temperature rise. Furthermore, if you want to specify more enhanced setting for limiting temperature rise, refer to '9.4.1.3 To Develop Slowly'. Also, in order to run other software comfortably while executing batch development, refer to '5.2.5 Low Priority Development'. This setting aims for verifying trouble of CPU thermal runaway caused by temperature rise. 9.4.1.4 Delete Manufacturer Name of EXIF InformationWhen this setting is checked, all development processes such as creating preview and thumbnail, 1-scene development, batch development and so forth are executed slowly. By executing development process slowly and reducing the amount of load placed on CPU, heat generation of CPU can be controlled. If the thermal runaway occurs while executing development process and changing development parameters, you should check this setting. If the thermal runaway does not occur when you check this setting, there may be a problem about the countermeasure of heating in your PC environment. If you continue to use a PC in this condition, the thermal runaway may give some damage to your PC, for example, break the data recorded in a hard disk. [Thermal Runaway] When this damage occurs, you need to stop using this software and execute the following measures. This "To develop slowly" aims for only discovering trouble. Even though a PC runs with stability in this mode, it is dangerous to use it continuously in this condition. In the case of thermal runaway, there is a high possibility that breakage of data recorded in a hard disk will occur. This is quite different from a case that program runs abnormally and completes. At the worst, the OS itself will not start up, and all data will be lost. We strongly recommend you not to use your PC continuously in this "To develop slowly" enabled. 1. Is there any obstacle around a cooling fan in a PC? You need to check whether dust clogs a fan or a fan is covered with dust. If it is too dirty, you should clean it according to a manual of your PC. 2. Is PC installed at an appropriate place?You need to check whether a wall blocks ventilation of fan or thermal radiation because a wall is too close to a PC. You should avoid locating a PC where heat stays. Rather you should install it where ventilation is good. 3. Please consult a manufacturer.If a room temperature is high, you should be careful for heat radiation from a PC. You may install it near to an air conditioner. SILKYPIX® Developer Studio runs a CPU with high efficiency. Because of this, we say that a temperature of CPU gets higher than a case of running other software. 4. In the case of a self-made PC, please enhance countermeasure for cooling.However, if a PC does not stand the heat, a problem does exist in a PC. If thermal runaway occurs even in an appropriate locating condition, there is a possibility that PC's countermeasure to heat is not perfect. You should consult a manufacturer about this thermal runaway. You may be suggested to initialize BIOS or update it. You need to follow directions given from a manufacturer to take measures. Is grease between CPU and heat sink sufficient? Is capacity of fan enough? Is ventilation in a PC ensured? Please enhance a heat radiation capacity. It is quite effective to open a PC and to blow air directly from a fan into it. This setting aims for avoiding the trouble which the EXIF information is displayed incorrectly by some other software like an EXIF viewer tool. ![]() 9.4.2.1 Disable Parallel Processing When Developing ![]() As the result, there is a possibility that SILKYPIX® decreases the other software's operations that are running simultaneously because the microprocessors are handling heavy loads during development processing. This setting is used when you want to reduce slowdown of other software's processing speed during development processing, or to avoid any trouble causing errors during development processing. 9.4.2.3 Delete Manufacturer Name of EXIF Information This setting aims for avoiding the trouble which the EXIF information is displayed incorrectly by some other software like an EXIF viewer tool. 9.5 Key Customization The menu command [Option(O)]-[Key customization(K)] displays the "Key customization" dialog in which you can customize shortcut keys.
• Assign key to the Function Select a function from the [Function] list at the left side of the dialog at first. • Initialize the assigned key to the defaultNext, select a key to assign to the selected function from the [Key assignment to the function] list at the right side of the dialog. Click the [Apply] button to assign the key to the selected function. Select a function from the [Function] list at the left side of the dialog at first. • Initialize all keys to the defaultClick the [Default] button and then click the [Apply] button, to initialize the key setting of the selected function. Click the [Init all] button to initialize all key's settings to the default. 9.6 Default Parameter Setting ![]() You can register the taste as the default parameter, which was registered to "All parameters" of "Taste category". "(SILKYPIX® Default)" is the default setting prepared by SILKYPIX®. If you select a "partial taste" for the default parameter, it is mixed for "(SILKYPIX® Default)" and the composite development parameter is assigned as the default parameter. [Attention] The default parameter must be modified carefully. When you modify the default parameter, the developed result of all scenes which a development parameter isn't set to is changed all together. Even if it is the scene which was browsed or developed in the past by SILKYPIX, the developed image is not compatible with the past in case of the scene which was not set a development parameter. As for the scene which a development parameter was once set to, it doesn't have an influence therefore. * You can check whether a development parameter was set or not by "Dropdown list for Taste". If the development parameter was not set and it is same as the default, it's taste is displayed with green color. * This function is valid only for RAW. You cannot specify the default parameter for JPEG/TIFF because it is fixed. 9.7 Option Feature 9.7.1 Make Thumbnail Files of All Scene ![]() This function deletes an access history to files/folders. 9.7.3 Initializing Location of ControlThis function initializes the location of all controls to the default. 9.7.4 Select SkinThis function allows you to change the background skin of this software. It displays the "Select skin" dialog, and you can select a skin on the dialog. This setting will be applied after re-execution of this software. To display with the new skin, please close this software once and re-execute it. 9.8 Customize Control Location This is a feature that allows you to change each control location. You can put sub-controls to the "tab page" or the "control box", or change to a floating window. And also you can change entire "parameter control" location. This is a very convenient function that allows you to compare two or more parameters and allows you to see and verify all of the pictures on the screen. [How to use] 1. About the sub-controls located on the "tab page" or the "control box" within the "parameter control" (for example "Exposure bias" or "White balance" as default) , you can change these sub-controls to a floating window by system menu command that is appeared by right-clicking on the title bar area of each sub-control.
2. You can change the entire "parameter control" to a floating window. The menu command [Option(O)]-[Display setting(D)] displays the "Display setting" dialog, and you can change setting of "Control location".
3. About the sub-controls displayed as a floating window (for example "Tone curve" or "Histogram" as default) , you can change these sub-controls to locate in the "control box" within the "parameter control" by system menu command that is appeared by right-clicking on the title bar area of each sub-control. You need enough display space for the "control box" area to locate any sub-controls.
Copyright (C) Ichikawa Soft Laboratory 2004-2007. All Rights Reserved. |
