9. Option and Setting
9.1. File output settings
9.1.1. Taste
Selecting a taste
If settings need to be changed based on the usage of the developed image file, you can switch settings at the development processing stage by registering the setting to taste without calling up the “File output settings” dialog.Registering a taste
When you click on, the “Add setting taste” dialog will be displayed.
9.1.2. Setting of File Type
In this software, you can save a TIFF file format and a JPEG file format.
Settings for recording and saving in JPEG / TIFF formats will be explained here.
TIFF is a format for saving images without deterioration through no compression or reversible compression.
Use this if you will further process images on other software.
Make settings here for recording and saving in JPEG / TIFF.
Determining which format, JPEG or TIFF, you will record and save is set at the time of development processing.
JPEG settings
Make settings when saving as a JPEG image file.
The higher the quality, the less deterioration to the image, but the size of the data to be recorded will be larger.(A) Quality
“Type” and “Quality” can be set at will only when “Custom” is selected.(B) Type
Culled color information and Exif information existence are the two main types when compressing images.(C) Quality
When 100 is indicated, there is no image degradation through quantization.[Culled color information]
When color information is culled, the expression of border colors becomes rough.[Differences between “Exif conforming” and “With Exif information”]
TIFF settings
Make settings if saving as a TIFF image file.
“Type” and “Compression format” can be set at will when “Custom” is selected.(A) Type
You can select “RGB 8bit” or “RGB 16bit.”
If you will further process development results from SILKYPIX with photo retouching software, saving to the 16bit higher gradation is advantageous.
SILKYPIX is not compatible with recording and saving to color spaces other than RGB, such as CMYK.(B) Compressed Format
You can select from three formats: “Uncompressed,” “LZW low compression” and “LZW high compression (LZW + Prediction compression)” (*1).
“LZW low compression” and “LZW high compression” are reversible compressions, so there is no degradation to image quality.*1 Please note that some software is not compatible with “LZW high compression (LZW + Prediction compression).”
9.1.3. Default folder to save
You can specify the default folder to save the developed JPEG/TIFF files. This is a default setting for the “Save as” dialog and you can modify to any folder for saving every time.
9.1.4. JPEG/TIFF options
When the development result is saved in the JPEG/TIFF file, incident information is saved together, for which option is set on the Option for JPEG/TIFF.
This setting does not have any influences on the results of the picture. Only the incidental information recorded in the image is influenced.
Resolution
The recorded “resolution” in JPEG and TIFF is defined here. The default setting is 300dpi.
If a software is not compatible with the dpi information, this setting does not have any meaning. If you do not understand this setting well, please use the default setting.Record ICC profile
You can specify whether to record the ICC profile which indicates color space into an output JPEG/TIFF file. It is checked in the default.
When you record the ICC profile, it is recorded using a method that conforms with the standards of either JPEG or TIFF.
If you are using the photo retouching software which is compatible with color management, namely, a recorded profile, it can transfer the color space information correctly.Discard SILKYPIX parameters and image information
This setting allows you not to record the information into a JPEG/TIFF file, which is the information about taking a photograph and the development parameter of SILKYPIX. This setting is not checked in the default.
Please use this setting if you do not want to disclose the information about taking the photograph and developing with SILKYPIX Developer Studio Pro9 / 9.Discard thumbnail
This setting allows you not to record the thumbnail into a JPEG/TIFF file, This setting is not checked in the default.Discard orientation tag
This setting allows you not to record the orientation information to the “Orientation” tag of Exif. This setting is not checked in the default.Set ‘CustomRendered’ as ‘Custom’
Since SILKYPIX assumes the output of the complete image which incorporated the intention of the user, it expects a next process to disable or minimize any further processing in the default setting.Capitalize extension
This setting is a capitalize the extension of JPEG / TIFF image files when you save the develop.
The default setting is disable.Set date taken to file creation date
This is a setting for creating / updating the date and time as a file attribute in JPEG / TIFF image files that were recorded and saved from development results.
9.1.5. Output options
These are the setting how to develop to a JPEG/TIFF file. These setting affect the developed image itself.
Rotate and save images
When this setting is checked, a developed image will be rotated as same orientation as a preview image.Rotation info is written in Exif info.
9.1.5.2. Output color space
Specify in “development settings”
Developments are processed in an output color space of either sRGB or Adobe RGB as designated in development parameters if this setting is selected.sRGB color space
Develop with the output color space fixed at sRGB, regardless of the development parameters.AdobeRGB color space
Develop with the output color space fixed at Adobe RGB, regardless of the development parameters.Convert to designated color space
When saving development results, the default name set as JPEG and TIFF image file names is given.
By default, RAW data files are set to the same base name (“%N” control characters).
[Control characters for specifying default filename]
%N : Basename of the RAW data file (“Basename” means a part of filename except the extension)
%L : Focal Length
%F : F Number
%T : Shutter Speed
%I : ISO Speed
%Y : Date Time - Year (2 digit)
%y : Date Time - Year (4 digit)
%M : Date Time - Month
%D : Date Time - Day
%h : Date Time - Hour
%m : Date Time - Minute
%s : Date Time - Seconds
%% : Method of describing ‘%’
9.2. Display settings
* Please refer to “9.9.3. Select skin” concerning switching skins (= background image).
9.2.1. Color management
* This setting is only available on the Windows version.
The preview image cannot display accurate colors if it is a JPEG / TIFF image recorded in an input color space other than sRGB and if the output color space is set to something other than sRGB when color management is disabled.
* In the macOS version, this automatically succeeds the monitor profile set on the macOS and displays the program.
Therefore, there is no “Color management” item in the macOS version.
Please refer to “10.4.5. Color management” for details.
9.2.1.1. Monitor profile
Please refer to “10.4.5.4. Color management on monitor displays” for details.
9.2.2. Thumbnail window
Image width
You can select a pixel width that has no blank spaces in the thumbnail window by clicking on the round mark at the bottom of the slider.Sort thumbnails
9.2.3. Preview window
Detailed rendering (Coarse preview → Development preview)
Use this under normal circumstances.Fast rendering (Coarse preview)
9.2.3.3. Grid Settings
Hide “Grid settings” dialog in grid mode
You can make settings for grid position and interval on the grid settings dialog, but even if the dialog is not displayed, changing the grid position can be made through operations on the keyboard ([Ctrl] key + left drag), so if the display is not needed, disable it.Show grid while adjusting “Rotation/Shift lens effect”
9.2.3.4. Partial Correction Tool Settings
- Brush overlay color
This is a setting for overlay color displays shown when drawing / editing the Brush in the Partial Correction Tool.
Stay in preview mode
The mode does not change, staying in preview mode.Change to thumbnail mode
Switch to thumbnail mode at the same time you open a folder.Change to combination mode
9.2.3.6. Background colors
9.2.3.7. Blink preview frame during preview rendering
9.2.4. Others
- Enable smooth scrolling
9.3. Function settings
The menu command [Settings (S)]-[Function settings (U)] displays the “Function settings” dialog in which you can set a method of saving the rotation for JPEG/TIFF/DNG, a brightness level of exposure bias tool and so forth.
9.3.1. Functions
9.3.1.1. When a JPEG/TIFF/DNG image is rotated
When rotating the image of JPEG/TIFF/DNG files, there are two ways to record the rotation information. You can specify whether or not to overwrite rotation information in the original file.
Save the rotation information to the parameter file (Never modify the original file)
The rotation information will be recorded in a parameter file, and the original file is not modified.Modify the orientation tag (Modify the original file)
Since the rotation information is overwritten in the original file, other software (*) besides SILKYPIX Developer Studio Pro9 / 9 can recognize rotation information.
You can set a threshold value to execute the highlight warning.
This value must be specified as a ratio to the maximum pixel value of the developed image.
You can set a threshold value to execute the shadow warning.
* The default value used to be 0.5(%) for both the shadow / highlight sides in SILKYPIX Developer Studio Pro 8 and earlier, but it has been changed to 0.1(%) in SILKYPIX Developer Studio Pro9 / 9.
9.3.1.8. Tooltip
Set the tooltip display.
Information button
When you push the information button, a manual for the concerned portion will open.No information button
Display the tooltip without the information button.Do not display tooltip
Do not display the tooltip.
9.3.1.9. Handle only RAW images
You can select this option to operate a RAW data file only.
When this setting is not checked, RAW/JPEG/TIFF files are displayed together.
When this setting is checked, only a RAW data file is displayed.
* The RAW data extension for EOS-1D and EOS-1Ds is “TIF,” so if this setting is checked, you will not be able to process such RAW data.
* Files in DNG format are handled as a type of RAW image.
9.3.1.10. Develop JPEG/TIFF images
You can switch settings for whether JPEG/TIFF images will be developed.
This is the same as “4.8.4. Develop JPEG/TIFF images”.
9.3.1.11. Treat the same base name (file name without extension) files as a single image
This is a setting to determine whether or not to treat RAW data and JPEG / TIFF images with the same name as a group.
When OFF, RAW data and JPEG / TIFF images with the same name will be displayed on thumbnails.
The default value is ON due to compatibility with DCF standards.
9.3.1.12. Open last accessed folder when starting
9.3.1.13. Create data file for the lens profile
This displays a message dialog to confirm whether to create a data file for the lens profile when the software is launched and creates a data file.
When this setting is turned OFF, the confirmation message dialog will not be displayed even when a data file needs to be created.
However, if a data file is not created, distortion correction functions using the lens profile cannot be used.
Also, please note that data files will not be recreated even when the lens database has been updated.
* Please refer to “4.11.4. Lens profile” for information about distortion correction functions using the lens profile.
9.3.2. Operations
Continue a tool operation after using the tool by clicking
In addition, when you use these tools with [Shift] key, the “one shot” and the “continuous operation” function oppositely to the setting.Delete without confirmation
If this setting is checked, you can delete a file without confirmation.Do not display confirmation dialog when starting batch development
If this setting is checked, a confirmation dialog will not be displayed.Do not display error message during batch development
If this setting is checked, a message will not be displayed even if an error occurs.Enable the mouse wheel operation on the control box to change parameters
If this setting is not checked, values will not be changed when the mouse wheel is operated on controls.
9.3.3. Performance
9.3.3.1. Cache settings
Restrictions
You can apply this setting if you are using a PC that does not have a lot of memory.Standard (default)
It’s a standard setting.Maximum
Maximize the use of Cache
Priority high (priority to the thumbnail display speed)
This makes maximum use of the CPU processing capacity, so the display speed of thumbnails will increase, but the overall operation of the PC may slow down.Normal (default)
This setting maintains a balance between thumbnail generation speed and the overall operation speed of the PC.Priority low (no priority to the thumbnail display speed)
9.4. Shortcut keys settings
9.4.1. GUI Operation methods
Function category
When a selected “Function” can be maintained, the status of the selection does not change, even if the display is switched here.List
“New shortcut key(s)” displays only those functions whose key assignments have been changed.Software keyboard
[Ctrl +] indicates pushing a “key” while holding down the [Ctrl] key.Initialize
Changes will not be made until you click on the [OK] button.Export
This includes settings changed through the “Shortcut keys settings” dialog that have not been confirmed.Import
Open the “Shortcut keys settings” dialog
The “Shortcut keys settings” dialog will be displayed through any of these methods, but if you designate a special “Function” and open the “Shortcut keys settings” dialog, a dialog for the selected status of that “Function” will open.a) Select [Settings (S)]-[Shortcut keys settings (K)] from the menu
b) Open the “Shortcut keys settings” dialog from various items on the menu
The “Shortcut keys settings” dialog will be displayed as the status of the selected “Function”.c) Open the “Shortcut keys settings” dialog from an icon on the toolbar or elsewhere
Select functions you want to assign shortcut keys
Depending on how you open the “Shortcut keys settings” dialog, the intended “Function” is already selected, but if you open the “Shortcut keys settings” dialog using method (a) above, select a shortcut key from the list of Function you want to assign.Assign a shortcut key to selected “Function”
9.4.3.1. Reserved keys
- [F1]
- [PageUp]
- [PageDown]
- [Home]
- [End]
- Ctrl+[A]
- Ctrl+[C]
- Ctrl+[V]
- Ctrl+[+]
- Ctrl+[-]
- Alt+Ctrl+[0]
- Shift+[Up Arrow]
- Shift+[Down Arrow]
- Shift+[Right Arrow]
- Shift+[Left Arrow]
- [Attention]
* “Default parameters” affect only RAW images. For JPEG/TIFF images, “Default parameters” are predefined values and cannot be changed.
9.6. Customize toolbar
You can also select [Customize toolbar] from the context menu displayed by right-clicing on the toolbar.
Current items
A list of items (icons) currently displayed on the toolbar.Available items
A list of items (icons) that can be added to the toolbar.Add
Add items (icons) selected in “Available items” to “Current items”.Remove
Remove items (icons) selected in “Current items”.Move up
Move up the display position of an item (icon) selected in “Current items” to the position above.Move down
Move down the display position of an item (icon) selected in “Current items” to the position below.Insert separator
A separator is inserted at the position of an item (icon) selected in “Current items”.Reset to defaults
* This setting is saved for each size of the skin that can be selected in “9.9.3. Select skin”.
9.7. Imprint data settings
Imprint data list
These two are maker data prepared by our company and user data created by you.Maker data
These cannot be deleted or exported. If edited, they will be registered separately as user data.User data
Edit
Edit selected data.Create new
Create new data.Copy
Create a copy of selected data.To upper
Move display position of selected data up one.To lower
Move display position of selected data down one.Hide / Show
Maker data cannot be deleted, but this setting will cause data to no longer be displayed in the list.Delete
Delete selected data.Rename
This changes the name of the selected data.Export all
Export all user data and save to a file.Export
Export selected user data and save to a file.Import
9.7.1. Edit imprint data
- Data name
- Characters for imprinting
- Image for imprinting
- Base size of data
Edited image display area
Display an image of data being edited.Name
This name is displayed when selecting imprint data.Edit control
9.7.1.1. Layer settings
Add layer
You can add images and/or characters.Copy layer
Copy selected layer.Delete layer
Delete selected layer.List of layers
9.7.1.2. Character settings
Standard point
The standard point is displayed as a red point in the left preview.Position from standard point
Set the position of a point on the edge of the image that was set as the standard point from the point on the edge of the image data that was set as the standard point.Size
Set character size.
When composition mode automatically adjusts the size, if the standard size of imprint data is changed to match the size of the image, the height will change at the same ratio.
If a fixed size is being used in the composition mode, imprinting will be performed at the set size.Setting details
It is possible to use control characters in the character string. Click on [Focal length], [F number], [Shutter], [ISO speed], [Date], [Time], [Comments] and [Title] to automatically enter control characters.[List of control characters]
%L : Focal length
%F : F number
%T : Shutter speed
%I : ISO speed
%l : Lens
%c : Model
%Y : Date/time of photograph – year (2 digits)
%y : Date/time of photograph – year (4 digits)
%M : Date/time of photograph – month
%D : Date/time of photograph – day
%h : Date/time of photograph – hour
%m : Date/time of photograph – minute
%s : Date/time of photograph – seconds
%n : Filename
%C : Comment
%t : Title
%% : Description method for ‘%’
%{ : Description method for ‘{‘
%} : Description method for ‘}‘
%r : Description method for Enter
%?x{string} : Conditional imprinting
9.7.1.3. Image settings
Standard point
set the position of a point on the edge of the image that was set as the standard point assigned control.Size
If a fixed size is being used in the composition mode, imprinting will be performed at the set size.Selecting image
Read an image.
9.7.1.4. Base size
Base size
Set this standard size.
The composition mode for imprint data when printing and developing can be designated, but if a fixed size is being used in the composition mode, imprinting will be performed at the set size.
When composition mode automatically adjusts the size, the ratio of image and character size will remain the same as the base size and the size will change to fit the paper and output size.Preview
9.8. Import and export settings
- File output settings
- Display settings
- Function settings
- Shortcut keys settings
9.8.1. Export
Save file
Designate a folder and file name for the file to be recorded.Settings to be exported
* When you import a setting file exported from SILKYPIX Developer Studio Pro9 / 9 in a previous version, some settings are lost in a previous version.
9.8.2. Import
9.9. Options
9.9.1. Delete access history
9.9.2. Initialize window positions and display states
9.9.3. Select skin
This new skin is only visible after restarting SILKYPIX Developer Studio Pro9 / 9. To display with the new skin, please close this software once and re-execute it.
9.9.3.1. Large-sized skin
9.9.3.2. Skins for high-resolution monitors
9.10. Troubleshooting settings
9.10.1. Initialize user configuration files
9.10.2. Delete data file for the lens profile
Delete the data file created for performing distortion correction using the lens profile.
When a data file needs to be created, a message dialog will be displayed to confirm whether to create it when the software is launched.
Create a data file again as needed.
Please refer to “4.11.4.5. About create data file for the lens profile” for information about data files for the lens profile.
9.10.3. Product key registration test
If it is determined that you cannot perform online registration of your product key, enter your “Serial number” and “Product key” in the “Product key registration” dialog and register offline by clicking on the “Offline registration” button.
9.10.4. Troubleshooting settings
9.10.4.1. Prohibit parallel processing during developing
Furthermore, if you want to specify more enhanced setting for limiting temperature rise, refer to ‘9.10.4.2. Develop slowly’.
[If you believe SILKYPIX is not properly operating due to thermal runaway]
When this damage occurs, you need to stop using this software and execute the following measures.Is there any obstacle around a cooling fan in a PC?
You need to check whether dust clogs a fan or a fan is covered with dust. If it is too dirty, you should clean it according to a manual of your PC.Is PC installed at an appropriate place?
If a room temperature is high, you should be careful for heat radiation from a PC. You may install it near to an air conditioner.Please consult a manufacturer.
SILKYPIX Developer Studio Pro9 / 9 runs a CPU with high efficiency. Because of this, we say that a temperature of CPU gets higher than a case of running other software.
You may be suggested to initialize BIOS or update it. You need to follow directions given from a manufacturer to take measures.In case of a custom-built PC, please enhance countermeasure for cooling.
9.10.4.3. Delete manufacturer name from Exif information
9.10.4.4. Restrict simultaneous file access
