6.1 Highlight/Shadow/Outside of the Color Gamut Warnings When you click the button, you can specify each warning.A warning will be displayed blinking on the picture in preview mode. (1) Enable Highlight warning The place where lightness and color are saturated blinks.The place where lightness is saturated blinks in black and where the lightness is underexposed blinks in white. This function is convenient for adjusting exposure. In addition, since a warning is given for a saturated color in an inversion color (negative), you can use it conveniently when you adjust saturation. ![]() This gives a warning for the shadow portion that seems to be black in contradiction to the highlight warning.
highlight warning and shadow warning simultaneously. This gives a warning for the portion where saturation is higher outside of the color gamut.Refer to '10.7 Creating Color Gamut and Adjusting Outside of the Color Gamut' about the color gamut. The menu [View(V)] - [Tone curve(T)] starts up the "Tone curve" dialog. You can set the curve which exchanges lightness while editing a picture. The horizontal axis means input (brightness of source picture) and the vertical axis means output (brightness of result picture after exchange). You can control lightness in a picture by operating this curve.* By dragging window's frame of the "Tone curve" dialog, you can adjust a size of the dialog. In addition, by dragging it while pressing the Shift key, you can adjust the size while fixing aspect ratio of it. 6.2.1 Editing Points The curve is drawn as passing through a point, and you can operate the curve by moving the point. During the operation, coordinates are displayed at the right side of the "Init all" button. Guide display function: When there is a cursor on the preview, a value of the position is displayed. (1) Adding Point
Drag the mouse in this state to move the existing point.
In addition, you can delete the current point by pressing the Delete key. You can delete up to the last two points.
By pressing the Delete key, you can delete this current point. ![]() (1) Type Combo Box ¥¥¥You can select the value which you want to operate a gradation process in a combo box.
(2) "Init" button ¥¥¥Initializes the lightness setting. (3) "Init all" button ¥¥¥Initializes the all tone curve settings of RGB, R, G, and B. (4) Guide display ¥¥¥Displays a value of position where a cursor is on. (5) "Add point" button ¥¥¥Adds a point on the presently selected type of tone curve by moving the eyedropper icon on the preview and clicking the point to edit (By clicking the point while pressing the Ctrl key, you can add a point on all tone curves of RGB, R, G, and B). * '(4) Guide display' and '(5)"Add point" button' are valid only when all points are monotone increasing or monotone decreasing.
(1) "Straight" Connects placed points with a line segment. (2) "Curve" Connects placed points with the smooth curve which passing through the points.
"Histogram" displays a brightness distribution on a picture. You can check which part of the picture has what kind of brightness.The horizontal axis means brightness (0 - 255), and the more it goes to the right side, the more brightness increases. The vertical axis means the number of pixels that corresponds to its brightness. R, G, and B are displayed in each color on a graph, and the place where these overlap is displayed in additive color mixture. 6.3.1 Histogram: Mode
(1) Auto
(2) Manual
You can adjust the scale on the axis by operating the below slider. The scale gets rough as you move it to the left side, and it gets minute as you move it to the right side.
(1) Contrast center
(2) RGB marker
* These are default settings, and you can customize the keys. Refer to '9.6 Key Setting (Customizing).' 6.4.1 Operating Menu Bar
6.4.1.4 Display
