![]() 9.1.1 Setting File Type
We recommend you to use TIFF when you do not want to deteriorate a developed result in this software or when you process a file with photo retouching software. When you process a file with photo retouching software, it is advantageous to save it as the 16-bit data that are useful for high gradation. When you want to reduce a saved file size, JPEG is suitable for saving. However, since a picture will deteriorate, you should set an optimal compression ratio as usage. In addition, you can record Exif information in an output file. Refer to '13.2 Exif Information' for details. ![]()
RGB Exif-TIFF (8-bit)
This can include EXIF information. In this case, you should check the "Recording Exif-IFD" checkbox. * The reason that this is not 16-bit Exif-TIFF is that saving in 16-bit is not prescribed in the Exif Standards. ![]()
Regarding the quality factor, if it is smaller, then a file size is also smaller. If it is larger, then a file size is also larger. In addition, if quality factor is larger then image quality degradation is less. Exif-JPEG (YCC422)
This is the most popular formation. Since only the color information in 1 pixel per lightness information in 2 pixels is recorded, the compression ratio becomes higher. However, color separation degrades at a fine area.
In comparison with the YCC422 above, its color information is less and image quality degradation is more. So its file size is small.
This can include EXIF information. In this case, you should check the "Recording Exif-IFD" checkbox. * Since the 444-sample format is not prescribed in the Exif Standards, this format is expressed in this way. ![]() Set the DPI information in dpi. If you check the "Not to record orientation " the rotation information will not be outputted to an EXIF tag. * Even if you increase this dpi setting, resolution of an outputted picture does not change at all. When displaying or printing a picture, only the scale for transforming to an actual size does change. Also in a case of the software which is not compatible with the dpi information, this setting does not have any meaning. So if you do not know much about this setting, you can use the default setting. ![]()
When you do not execute rotation, a picture itself is not rotated but outputted into a file (When an output file is created, its direction is the same direction that is recorded in an input file). If you uncheck the "Not to record orientation" checkbox, the rotating image is written into a file (When you use the tool which is compatible with rotation information, a picture is rotated and displayed). ![]() If you are using the photo retouching software which is compatible with color management, namely, a recorded profile, it can transfer the colorspace information correctly. ![]() Regardless of the colorspace which has been set as a development parameter, you can execute development with the colorspace of "sRGB" or "AdobeRGB." For example, it is convenient when you re-execute development with "AdobeRGB" in order to print for the time being while normally executing development with "sRGB" in order to view on a monitor. ![]() 9.2.1 Color Management ![]() If you check "Enable display color management" checkbox, the profile which is associated with a monitor as a monitor profile is used and displayed. If you enable the color management, when you preview JPEG/TIFF files with adobeRGB or preview by setting "adobeRGB" as colorspace, correct colors can be displayed. Also, even in a case of using the color management only with sRGB, by creating a monitor profile after measuring a color of a monitor with a color matching utility etc. and then setting it in this software, correct colors can be displayed. If correct colors are not displayed, you cannot adjust correct colors. We recommend you to use the color management function. There is a case that some monitor manufacturer distributes a profile for a monitor. So you may check it out on a manufacturer's home page etc.. 9.2.1.1 Setting of Monitor Profile
(1) Use the default monitor profile in the OS. About how to specify a monitor profile to the OS, refer to your OS manual. (2) Select a monitor profile (ICC/ICM file) from files. Specify a monitor profile in XYZ-RGB format. In some software, you have to specify a monitor profile directly. In such a case, please note that the specified monitor profile may differ.
Select the easiest way to use.
![]() 9.3.1 Saving the Rotation for JPEG/TIFF/DNG ![]() • Save to the parameter file (Never modify the original file)
Since rotation information rewrite the original file, other software (*) besides SILKYPIX can recognize rotation information. However, when no rotation information is recorded in a file, rotation information cannot be rewritten, and it is recorded in the parameter file (.spj, .spt, or .spd). ![]() The term "brightness level" here means a value of linear (photo energy) level at the point you click. In other words, it is a value before adjusting tone representation, gamma and tone curve. Therefore, even if you set 50%, a pixel value at the point does not become 127. When normal tone representation and tone curve are set, the value becomes the brightness level which is displayed on a display. You can consider that the set value is a sensitive level on RAW data. For example, when setting the value as 18% and using the exposure bias tool by specifying 18% gray card portion, you can obtain the exposure bias value which can reappear with 18% sensitive level on RAW data. You can obtain almost the same result as a case of determining an exposure level by using an exposure meter. Even when not using a gray card, you can adjust an exposure level to a certain level easily by specifying the brightest portion on white paper or a picture with a set value of this tool as 90% since a reflection factor of white paper is approximately between 80 to 90%. You can apply this technique when taking multiple scenes of the same picture or reappearing the same area with certain brightness. ![]() You can set a ratio for the maximum pixel value of the final output picture. ![]() You can set a ratio for the maximum pixel value of the final output picture. ![]() If this setting is not checked, the modified development parameters and rotation information are lost when the application is finished or when a new file or folder is selected. If this setting is checked, data files with spd, spj, spt, spi etc. for SILKYPIX are created automatically in the folder in which a RAW picture exists. When this setting is not checked or a storage media is write-protect, these files are not created. ![]() When this setting is not checked, RAW/JPEG/TIFF files are also displayed. When this setting is checked, only a RAW picture is displayed. * Since extension of RAW data for EOS-1D and EOS-1Ds is "TIF", when this setting is checked, these RAW data cannot be operated. ![]() When this setting is checked, the operation takes place as if it is determined by selecting the folder by double-clicking. When this setting is not checked, you can open or close the folder by double-clicking. The opening and closing of a folder means to display or not display a sub folder under the folder. ![]() When you check this item, an operation mode does not change even if you specify a color with these tools, and you can continue to execute the same process. In addition, in these operation modes, when you specify a color by pressing Shift key, one-shot and continuous operation are operated in the opposite way as you have set. ![]() If this setting is not checked, you need to confirm when you delete a file. If this setting is checked, you can delete a file without confirming it. ![]() This is effective when you check details on a picture by switching two pictures on the preview screen. When you check this setting, memory space for cache increases. When you use a PC with little memory, please uncheck this function. • Only previous and next scene cache
By this, you check details on a picture by switching two pictures on the preview screen comfortably.
You can switch scenes quickly in the preview mode by the previous and next scene feed function. If you compare scenes by feeding to the previous and next scene with equimultiple pixels, you can check focus on the scenes that were taken in the continuous shooting mode and camera shake easily. Also, when executing putting development parameter on cloakroom, the development result is also cached simultaneously. When you compare scenes by switching the parameters on the cloakroom, you can switch to the preview quickly and run-in development parameters easily.
![]() By specifying the drive which has a virtual storage file of the OS and also the folder which exists in a physically different drive, performance may improve. When you specify a drive, you should specify the drive which has sufficient free storage space and also runs at high speed as possible. ![]()
Note that when you change settings by your own judgment, there is a possibility that a program does not run normally, or the performance drops significantly. ![]() ![]()
As the result, there is a possibility that SILKYPIX® decreases the other software's operations that are running simultaneously because the microprocessors are handling heavy loads during development processing. In addition, because the microprocessors are handling heavy loads, hardware operational failure has been reported. For example, a high temperature warning because of increased temperature of the processors, unstable operation, rebooting a PC and so forth. In order to avoid these trouble, this setting controls microprocessor activity ratio and limits temperature rise. Furthermore, if you want to specify more enhanced setting for limiting temperature rise, refer to '9.4.1.4 To Develop Slowly.' Also, in order to run other software comfortably while executing batch development, refer to '5.2.5 Developing with Low Priority.'
When this setting is done, all development processes such as creating preview and thumbnail, 1-scene development, batch development and so forth are executed slowly. By executing development process slowly and reducing the amount of load placed on CPU, heat generation of CPU can be controlled. If the thermal runaway occurs while executing development process and changing development parameters, you should enable this setting. When you enable this setting, the CPU thermal runaway stops. However, if it is just a case that a time until the thermal runaway occurs delays, there must be a problem in PC's countermeasure to heat. Because of the thermal runaway, if you continue to use a PC in this condition, breakage of data recorded in a hard disk and other damage may occur. [--->Heat Reckless Run] When this damage occurs, you need to stop using this software and execute the following measures. This "To develop slowly" aims for only discovering trouble. Even though a PC runs with stability in this mode, it is dangerous to use it continuously in this condition. In the case of thermal runaway, there is a high possibility that breakage of data recorded in a hard disk will occur. This is quite different from a case that program runs abnormally and completes. At the worst, the OS itself will not start up, and all data will be lost. We strongly recommend you not to use your PC continuously in this "To develop slowly." 1. Is there any obstacle around a cooling fan in a PC?
However, if a PC does not stand the heat, a problem does exist in a PC. If thermal runaway occurs even in an appropriate locating condition, there is a possibility that PC's countermeasure to heat is not perfect. You should consult a manufacturer about this thermal runaway. You may be suggested to initialize BIOS or update it. You need to follow directions given from a manufacturer to take measures.
You can open a PC and blow air from a fan into it. This is quite effective. ![]() ![]()
If this setting is operated, when resizing, only drawing a frame is processed. When this resizing is completed, drawing is executed in a window.
As the result, there is a possibility that SILKYPIX® decreases the other software's operations that are running simultaneously because the microprocessors are handling heavy loads during development processing. This setting is used when you want to reduce slowdown of other software's processing speed during development processing, or to avoid any trouble causing errors during development processing.
By the use of this function, you can comfortably execute operations while comparing multiple parameters, displaying a picture on the entire screen and so forth. [How to Use]
2. The menu [Option] - [Display setting] displays "Display setting" dialog. Select the "Display the control window as a floating window" to display the whole of parameter/control as the "Development Parameter" dialog.
3. When you select [Locate it in the control box] from the context menu (Fig.2) which is displayed by right-clicking on the text menu of each parameter dialog such as "Tone curve", "Histogram" and so forth. You can locate each control in each parameter/control. If a screen size is not sufficient, you cannot use this function.
• Assign functions to keys
In the "Assign of key to selected function" list on the right side, you can select a key. Press the "Apply" button, to assign the selected function to the selected key.
Press the "Default" button then the "Apply" button, to initiate the selected function key (default).
Copyright©2004-2006, Ichikawa Soft Laboratory. All rights reserved. |
